Hi, you can use the “Select Item” activity! Just highlight the element, and you will be given all the options in the drop down, and you can select the correct one! This will surely work for you!
i even tried after that “Take informative screen”
which did not help either or may be i should try write in quotes something different rather than “Red” (cause i think Uipath is not able to recognise that “Red” is written on an element i want to click)
@Vaka4life Assuming you want to Click on the “Red” option, Can you click on Highlight and check if it Highlights the right element that you want to click ?
@Vaka4life Have you tried using different frameworks ? Also In the Screenshot that you have provided you can see the Visual Tree Panel there are many items, Try selecting each Element in it and try to find the Element using that.
Thank you guys for responses. I finaly found the solution I used Computer vision activities they use AI that is why it is possible to find almost any element)
