This was not easy and I got through it on my second try. The more I practice, the better it becomes. Not sure how I feel about introducing bugs to fix so early, nonetheless I got through it.
This is quite challenging!. I need to follow steps bu step only can be able to do it!
Hi when I tried to add a gmail account account it give me the red icon even after doing the same thing that was mentioned in the video
addaccount–>selected default–>hit ok–>brower opened with gmail loginin page–>did all the things and closed the page–> then I see the red dot and also my email account is not stwitched to the Account column that we see the use gmail activity. Please help me on this
error:-object reference not set to the instance of the object
This was a great experience! I went through the exercise smoothly using Google Workspace. It’s incredible how much you can accomplish by throwing a few activities in.
Able to get everything working until the very last step, when publishing to UiPath assistant it stays on awaiting install, and gives an error of cannot read properties of undefined. I can run it without issue from studio x so there’s some disconnect between studio x and assistant but I can’t figure out what it is, I checked the forum for prior issues and confirmed it wasnt a firewall/its run as administrator, so I’m not sure why it’s not working, any advice would be appreciated!
(post deleted by author)
I gotthis error when trying to run the project in the UiPath Assistant :
UiPath Robot Error
Cannot read properties of undefined (reading ‘defaultValue’)
Hi , I need to copy data from CSV file to a specific google sheet, and then on need to write, include formula and use a fill handle, and so on. When creating an OAuth Client Id what is the ‘Application type’ I should provide, OTHER option is missing.
When I give ‘web application’ or ‘chrome app’ I am getting an error when running
Pease help
Thanking you
Nithya
Thanks @Cedillo_Gerardo, this fix worked for me! Well done for figuring it out ![]()
Hola. He hecho lo mismo que tú, por el mismo problema a la hora de llevar el código de descuento desde la web hasta la factura de la manera correcta. Sí que funciona así, pero el valor se suma en vez de restarse (código descuento). ¿Has solucionado esto? Me parece raro que nos de este problema, cuando son ejercicios que teóricamente deben funcionar siguiendo los pasos indicados.
Un saludo y gracias por aportar.
Got an error with the latest Google package, see my post here:
Dictionary datasource not supported for GSuite! when trying to write to cell e18, upon trying to select the + sign so I can grab the variable.
Very frustrating. Downgrading to Google package 1.11 was not an answer I could find anywhere in the forum, and I didn’t see the discussion at the bottom.
It was great but at the same time a little confusing for me. I could not see the ‘save for later’ option instead I had variables and other options that did not match the tutorial. But overall I was able to automate another process with this tutorial. Thank you
It was a great experience. I really loved it
Unfortunately on my office machine we are not allowed GMail. so it was not of much use to me
