BTN_RIGHT Click activity does not work with the SimulateClick option
Hello there. I need your help.
The problem is as follows.
Scenario: right-click desktop icons in “background” with the SimulateClick option.
(Next I will select the item with left-click)
Steps to reproduce: Any icon does not work. ex) the Explorer icon, the Network icon …
Current Behavior: Without the SimulateClick option, it works.
Expected Behavior: I want to automate in background with the SimulateClick option .
Studio/Robot/Orchestrator Version:2016.2.6344
OS Version:Windows 10 Pro
Hi @obi,
The Right Click on any desktop will work-fine When Simulate Click is UNCHECKED.
As you mentioned :slight_smile:
The RIGHT Click Does NOT work when Simulate Click is CHECKED
What I think the reason why this happens is :slight_smile:
SECNARIO - Right Click a Desktop Icon when Simulate Click is CHECKED
1.> When you right click on any desktop icon , the right click action is performed on that icon.
2.> By default , the first option when u right click an icon that you get is Preview or Open
So , Since you have checked the Simulate Click , after the Right Click action is performed , immediately
Simulate Click is performed.
Since, the clicks are performed twice , the icon (either file, folder, image ) appears to Launch.
But dont worry , even if you uncheck Simulate Click - It will work fine in background.
Make Sure you use attach Window and then perform such actions Click / Right Click activities .
Cheers mate
Hope that helps :slight_smile:
Thanks for your help @prassin6:grin:
mm…
With the SimulateClick option, it seems that right-click does’t work, but left-click works.
Do I misunderstand the SimulateClick option?
If I check the SimulateClick, there will be another click in addition to first one ?
How can I do it in background?
Regards,:grin:
Hi @obi
Can you please share what have you tried so far.
Also could you please, Share screen shot of what happens
1.> When Simulate click is unchecked
2.> when simulate click is checked.
It wud be helpful for me to understand the behavior.
There shouldn’t be one.
For me (Win10/2017.1.6522) SimulateClick → BTN_LEFT for a desktop icon launches the app as if it would be a double click. Probably wrong call is sent or there’s a misinterpretation. It works ok for stuff on the Start bar for some reason though.
BTN_RIGHT throws an Invalid Mode for all icons (desktop + start bar) I’ve checked.
Seems like a bug. Perhaps @ovi already knows something about it, if you’d please :slight_smile:
Use SendWindowMessages, seems to be working fine from what I can test.
Thank you both :grinning:
This is the situation I had.
It seems to me that left-click works instead of right-click with the SimulateClick option.
I hope that the bug is fixed.
Thanks again :grin:
Hi there,
It’s kind of a known issue in Windows 10, as @Gabriel_Tatu explains here:
