whats the major difference?
There is no difference between if else and flow decision.
so we can use in both the cases?
All are the same except for coding standard point if you want to invoke xaml on true condition or false set a flag as false for decision flow and if else is helpful for normal condition with to print the original output
Thanks
Ashwin.S
yes … but in flowchart we need to use flow decision and in sequence we need to use if else bcz flow decision is designed for flowchart template.
Hi , Both perform same function but different in purpose
If else: you can use this inside sequence
the problem with if else is you can not loop back to any previous scenarios from Then or from else part
Flow Decision , you can use inside flow chart only , and with the help of flow decision you can loop / navigate the flow to any scenarios / sequences
