Studio is not allowing me to insert a Flow Decision in my sequence. I get a circle with a back slash in it. Can anyone help?
We can’t use Flow decision inside sequence. If you want to use it then first drag Flowchart and then use flow decision.
I just found the answer and hope this helps someone else. My sequence was not part of a flowchart. It has to be part of a flowchart to use the flow decision activity.
Hi @lhendrix,
I think you have got the answer.
Flow decision activity only can be used in Flowchart.
For Sequence, you can use “IF” activity instead of “Flow Decision”.
Thanks, Toby and lakshman!
Why flow decision can only be used in Flowchart and not in Sequence ?
