Hi,I am facing an issue to use the On Element Vanish. Here I am waiting for the Pending status to finish. It takes generally 15-20 sec to vanish. But my bot sometime waiting for it to vanish or sometimes execute the next activity before vanishing the Pending status.
@Palaniyappan
Why dont you try leveraging the ‘Wait not active’ and ‘wait not visible’ check box in the properties panel of the same activity?
That should normally fix things because the element might exist int he page source which will lead to false positive. Try and revert if issue still persists.
Hi
kindly increase the TIMEOUT property with its value like around 60000
and enable Wait not visible (because it waits for the bot it that element vanishes and no longer visible on screen)
waitfor ready property set as complete and try once
Cheers @balkishan
yah enable this
Cheers @balkishan
Not working Palani,
Still it’s not waiting for the status to finish. It jump to the next activity, even I set the 90000 milisecond timer.
I am waiting for the Pending status to vanish. After 20-30 second how it changed. Attached the screenshot for both.
Hi still the same issue facing.
Use Get Attribute activity and indicate that element and aaname attribute has value that status value right. Then check whether it is equal to pending then wait some time else continue
Instead of on element vanish did we try with ON IMAGE VANISH
cheers @balkishan
No, I didn’t try bro.
Kindly try that and let know for any queries or clarification
Cheers @balkishan
Is the repeatforever property set to true
@balkishan
Not It’s False
Set that to true and increase the accuracy of the image and try once
Cheers @balkishan
How much Accuracy I have to set.
Not it’s 0.8
kindly try with
WAIT IMAGE VANISH activity instead of ON IMAGE ACTIVITY
or
WAIT ELEMENT VANISH activity instead of ON ELEMENT VANISH
Cheers @balkishan
