Uipath advanced level assignment level 2 Hashcode returning same values for different Client
Hello everyone,
I have stuck on the same issue last two weeks.
SHA1 Online GET HASH CODE returning same values for all different client code.
what should I do?
Any help would be greatly appreciated
Hi @Zehra
Please check if the workflow is properly passing arguments :slight_smile:
thanks bu I’ve already checked it, there is no problem with it. Any idea?
Can you upload the workflow? Thanks :slight_smile:
Okay.
It means that it doesn’t get the SHA1 result.
Please update the selector in the Get Full Text activity. The selector is dynamic :slight_smile:
thank you I tried but it is not the solution
thanks for your help
Have you already resolved it? :slight_smile:
yep done :slight_smile::slight_smile:
thank you @Jan_Brian_Despi
Good to hear that, @Zehra :slight_smile:
