But suddenly when i use the ocr activity its getting the error like
broker process path not found:C:\Users\xxxx.nuget\packages\uipath.vision\1.2.0\build\UiPath.Vision.Host32.exe
Yes, i installed all the packages for OCR but when i analysed am using CE before 4 days UiPath latest version as installed 18.4.1 automatically in that i could not see the Studio exe file itself
Correct i also couldn’t open the UiPath Studio itself.
So, manually am going into the older version and launching the old version of UiPath Studio exe file.
I would suggest a simple reinstall of the Studio CE 18.4.1. This should fix any corruption that might have happened to the installation.
Do not forget to restart your machine at the end to make sure all services are properly running.
Normally no, Studio CE resets the settings upon new installation.
If you find yourself having difficulty with some packages, you can try clearing this folder: %userprofile%\.nuget\packages
