Hi UiPath Team,
I am currently going through the “Selectors in Studio Deep Dive” module, but I am unable to access it. Each time I try, I encounter blank webpage.
Could you please check if there is an issue with the module or if there are any prerequisites I need to complete before accessing it?
Looking forward to your support.
Best regards,
Divya
arivu96
(Arivazhagan A)
2
Hi @divya-sai.tirumalareddy ,
Try below steps,
Clear browser cache
Try to uninstall UiPath extension and install again
Or
try it in different browser
Arivu
mkankatala
(Mahesh Kankatala)
3
Use a different browser to open the UiPath academy. Sometimes everyone facing issue with the same.
Hope it helps!!
@mkankatala
Thank you so much.
mkankatala
(Mahesh Kankatala)
6
If you find the solution,.make post Mark as solution to close the loop… @divya-sai.tirumalareddy
Happy Automation✌️
Hi UiPathians,
Actually nothing worked out for me. So then, I have chosen to reach out to the UiPath service desk.
So, they have resolved the technical in the backend.
Thank you.
system
(system)
Closed
8
