Hi There,
I am trying to run a process from a subfolder. I publsihed the process within that folder and assigned a machine + robot to that folder. The folder has its own package feed. As I run the process it can not seem to find a custom library that i have uploaded to the lbraries in the tenant. How should i set this up so that the process packages are picked up from the folder feed but the custom library that i have build/uploaded to production is fetched from the tenant? Do I have to adjust the standard robot role for this or is this a dependency issue, what is the best way to appoarch this?
This is happening to all custom libraries.
When running a process on an unattend robot with a custom library inside it it, i get the following error:
Cannot create unknown type ‘{clr-namespace:MailLibrary;assembly=MailLibrary}SendStatusReport’. at System.Xaml.XamlObjectWriter.WriteStartObject(XamlType xamlType) at System.Xaml.XamlWriter.WriteNode(XamlReader reader) at System.Xaml.XamlServices
Library has only uipath system.activities 21.10.4 and sharepoint activities 1.0.7 both on strict. The project in which it is used has the same version.
Kind regards,
Dyonn Bakker
