Hi all,
It something weird case but robot setting window below does not comes up in my other PC… I tried PC reboot but it still does not. Does anybody know something similar case or workaround???
Thanks in advance,
J,
Hi all,
Thanks in advance,
J,
Double-click the file → UIRobot.exe for system tray icon.
Search for the above file in your windows explorer.
Karthik Byggari
Actually I can find the icon in my system tray and I can even select ‘Open logs’ or ‘Help’ command from gear button… however not ‘Settings,’ option working…
J,
Might be this is because I don’t have admin authentication.
If so, does anybody know how to change the setting without the setting screen??
Thanks
