Read Range using variable as workbook path returning Illegal characters in path
please assist
i have all my filenames (full path + extension) in a multi-line string
so i assign it into a string individually for my process
strFileNameReadRange = strFileNames1.Split(cchar(System.Environment.NewLine))(intFileCounter)
strFileNames1 = multi-line string
intFileCounter = line of multi-line string
it can return me properly when i use a message box and write line
but when i put into workbook path of read range activity
below message occurs
the variable i put into the workbook path = strFileNameReadRange
can advice what is wrong?
info
i can’t do a for each activity using the multi-line string or datatable, as the process is quite long. so i use a decision at the end of the process to loop it back and increase the intFileCounter
Hi @wilfred
Kindly check ehther your read range variable or extension variables contains any whitespaces
Hi @wilfred,
Can you share with us a sample path for reference, so it would be easy to identify the error?
@90s_Developer
@wilfred
Can you share the correct input string you are making a split?
Also you can use writeline to see what the output you are getting from the split
Multilines are not allowed in the path of the file
Hope this may help you
Thanks
pls see attached for my RPA
this is simplified, so pls ignore the start when i assign strFileNames
the trouble is at the read range
ReadRangeUsingVariable.zip (20.0 KB)
I can’t detect any white spaces
@wilfred
Write as below
This is working fine without any issue
Hope this will help you
Thanks
@wilfred
Check below, there was a whitespace which is stopping you with the error
So adding Trim option then you can remove all the whitespaces
Thanks
thanks
i tried it and seems like it is working
i will do more testing
thank you for all your time…!
@wilfred
Once you done with your testing Mark as solution that which post solves your issue
So this will help others if they face similar issue
Thanks
