It looks like you are using RE Framework, so in your process directory under Data Folder you should have a excel sheet called “Config.xlsx”
You need to have the sheets in that which you are passing from your read range activity.
Debug and check the same at for which sheet you are getting error?
Hi @sunilraju,
1.Try to keep some data in the form of Name and value in the config sheet under data folder…
2.You have keep the values in the sheet as key value pairs…
If you find it useful mark it as solution…
Any doubts let me know…
Cheers.
Vashisht.
