Read Range activity error--Help
Hi, can anyone have the resolution for this error:
Every time while reading Excel file in loop i am getting this error, I have to read 3 excel and each excel file have 2 lakh of data. Sometime after reading two excel file, it s throwing this error , sometime after one.
Not able to replicate the exact issue.
Hi
Use a Kill process activity between each of read range activity which reads that excel file
That is first use a read range activity from excel application scope and then use a Kill process activity with ProcessName property mentioned as โ€œExcelโ€
Again use a excel application scope and a read range activity for second excel
Then a kill process
And another read range and a kill process
This will ensure that excel application is killed the moment it is used and read the data
Try with latest excel package
Go to UiPath studio โ†’ design tab-> manage packages-> all packages and upgrade excel package
Cheers @Anjali_Rani
Hi Thank You.
This is not worked for me.
But, I got the solution after so many trials.
Instead of Excel application scope, I used Read Range Workbook Activity and it solved my Issue.
Thank you.
Happy Automation :grinning:
