Hi all,
By default, in case of system exception flow, seems like the RE Framework processes all the transactions in Queue, before retry.
Is there a way I can retry the same transaction queue item and stop the flow, instead of processing all the transactions?(For Eg : out of 100 transactions, if the first one fails, I would want to stop my flow after retrying the same 1st transaction and leave the rest in ‘New’ status.
Is this achievable?
Hi @Krithi1
What u mean by stop the flow ?
Once the first transaction queue item fails with system exception, I want the BOT to stop the entire process, instead of processing all the 100 transactions and then stop. It has to retry the first transaction 3 times though before stopping the entire flow(Since the queue has the retry option is set to ‘3’ times in the orchestrator). That way I will have the rest of 99 transactions still set in ‘New’ status, so that the next BOT schedule will pick them up and process
