I create two attended robots which I want them to run on same machine. However, when I create the second robot and error occur said there is another robot connected to same environment so that I cannot created.
I am using default free orchestractor.
Is that means one machine can only contain one robot?
Ok…I see thanks …
I want to test two rpa run in same machine at the same time. And if I use uipath robot to start the two process together, will they run at the same time or run after the others?
yes once machine can be used to provision only one robot
usually robot created here in orchestrator is just a name for the UiPath Robot installed inyour machine
–where in your machine you have installed only one robot right…so we can create only one robot (a name) in orchestrator for that machine
And its the same for both attended and unattended type of robot
But still if we want to run two robots in same machine at a time or at different time
we should have installed HIGH DENSITY Robots to do that
for more details on it
I am not sure whether I need to use high density robot or not. …
As I am the only person to run the rpa. In other words, I want to put two rpa into same robot to run at same time. Does it require high density robot? Or will it be possible?
Thanks so much…It is a clear explanation…
But still I am confused in how to run two rpa in a same robot .I do not know whether high density robot is useful in my case or not…
I have understand the concept now. Thanks so much.
And I would like to ask is it possible to run 2 process in a robot in a machine? If I have two attended robot, is that high density robot is the only way to perform that?
