Problems with navigation inside mainframe
Hello,
I am working on a project in which I have to automate a process in a Mainframe (TN3270).
On the pic, it is my parameters for connexion.
connexion Terminal
I know how to navigate in the environment. But it happens many times that I have an error message that the robot cannot find a field.
I’m using the "wait text’ activity but even with this, it happens. I used “Delay” activity but it is not a good practice and it slows down the process. And even with this, I have error message that the field is not found.
Has anyone ever faced this problem before ?
It seems unstable.
Thank you by advance !
@DanielaD
@loginerror
Hi @najoua.abbaci
Please install the updated version of Terminal Activities Package (2.0.0-preview) and configure connection with Provider “Direct Connection”.
Thank you,
Daniela Dumitrasu
Thank you very much @DanielaD for answering me !
I will give a try and hope that it will solved this issue.
