Problem with running process in maestro folder - unattended mode
I’m unable to run bot in unattended mode under maestro process.
If i want to change to windows credentials what i have do here :
@reachRPA
provide the username and password details
the error says the same
cheers
You mean widows login ? Can you please add screenshot of yours that will help me to set up
@reachRPA
We cant send the screenshot of creds…but yes the machine login creds you want to use
domain\username is the username format and password is your usual password
cheers
Thank you working now.
