Problem with CV Scope/Click/attach Window not recognizing elements in Desktop application!
Hello All !
Problem is - basically I want pass dynamic Selector in Click Activity(row index)there is one table on desktop application from that i want to pass rowindex inside click activity but not able get selector and I am using Cloud Server for Automation! I have used CV Scope /Attach window but still not able get selector ! does any one know the Solution for ?
Thank you in advanced
@rohan.dhole
You are unable to indicate the elements in the window?
did you try with active accessibility mode as well?
cheers
I am able to indicate element in window but not getting selector !
Yes I tried with active accessibility mode as well !
@rohan.dhole
What error are you getting? when you say not getting selector?
cheers
@Anil_G
There is one data table in Application ! I want iterate that table and find specific row index ! after that I want pass that rowindex inside click activity to Click on particular row ! but in click activity I am not getting Selector !
@rohan.dhole
Can you show a screenshot of the same?
as it is desktop application mostly it might not be exposed as well
did you try with cv activities as well?
cheers
@Anil_G
Sorry but I cant show the application screenshot !
I tired as well that CV Activities ! Using CV Click I am getting only Text like (“Target: Text ‘($105.00)’ (495,447,50,14)”)
@rohan.dhole
try cv extract table get data and based on text you can do clicks
cheers
@Anil_G For Clicking dynamically we need selector ! Idx or rowindex ! these selector I am not getting !
@rohan.dhole
in cv you wont have those you needto go with the text value only
cheers
@Anil_G Thank you for suggestions ! I will try…
