i have an UI element, name, ui
I use Invoke Method activity, with target object ui,
and Method name is “Set”
parameters are
- in direction, String type, value “visibility”
- in direction, String type , value “2” (i.e. try to change the UI element to not visible and not visible in background too)
running this workflow results in no error, however the uielement is not set to hidden status.
can someone help to correct it such that I can hide the display element on the window in foreground as well as in background ?
