Why is it that when I download the Balareva package for Excel charts, the Excel Activities package doesn’t work, causing the activity to experience an error, what’s the solution?
Looks like there is some dependency conflicts between both…change either of the package versions and check whicha re compatible and use them
I’ve tried, but it still doesn’t work
do you have another solution?
How did you happen to try?
Expand them and check the versions used in both and find a common version
I have updated the excel activities package, as well as changed the version.
But still the error
Only upgrading is not what you need to do…expand the packages and check for common packages and downgrade thw package to match them
