PiP Options disabled in Project->General section
I am not able enable this PiP options as it is disabled by default. Please help.
Since everything is greyed out, I suspect your project.json file (or other files in the project) are set to read only. Close Studio. Make sure nobody else has this project open. Right-click the project folder and select properties. Uncheck read only, then apply to all files and folders.
