Iam not able to use outlook for automation, I have tried uninstalling and reinstalling the outlook but issue not fixed. I have tried restarting the studio as well, Still am facing the issue. Kindly refer the attached screenshot.
For using Outlook activities, outlook application has to be installed in your machine.
If installed first login to the Outlook then you are able to see the accounts which are logged in outlook will show in the dropdown in Use Desktop outlook app activity.
If you don’t have Outlook installed instead of using the Outlook activities use the Send SMTP Mail Message acitivty to send the mails and use the Get IMAP Mail Message activity to read the mails.
Hope it helps!!
You can put the folder names like this.
The option there you get it’s just Studio intelligence which sometimes fails to load.
Thanks,
Ashok ![]()
Hi Mahesh,
Thanks for the reply. In drop down my account is not getting detected even after I tried logging in my desktop outlook app several times. Then I tried to fix the issue with “Repair tool for MS office”, But iam not able to create .REG file for outlook. PFB the screenshot.
Hi Ashok,
Thanks for the help.
My studio is not even detecting the account which i logged in on outlook app.
