started in UiPath back then but gave up because i have no clue how this works and been stuck jumping on other webscraping apps since july 2023 and been wasting months of my time there (WORSE MISTAKE!!)
Now i came back to UiPath again when i found these Articles that mentions ALL that i need! Screenshot UiPath Automation Cloud Robot - Serverless. what i need is i have a txt file that has massive website links and i want to upload it to UiPath or if it allows i can paste it all there or link a txt file from gdrive then i want it to open EACH links in the txt file then i want it to open the website (IF POSSIBLE before screenshoting i want it to detect then open/click all drop downs to open,etc etc so it reveals all the hidden infos in the site that you need to click to view to see because all the dropdowns that has hidden info in pages example wikipedia if all not opened then screenshoted makes the screenshot useless/unhelpful . Then after revealing all the hidden infos /dropdowns of the website I want it to screenshotthe Whole page! (in highquality if possible even if the site is long it should go all the way so no info is left out) then all Screenshots will be named after the website (if possible only) then Uploaded to my gdrive (google one 2tb). Can someone pls send me a run file that does this for cloud serverless run Pleaseee
