Multi Login using SingleSignOn on same machine
Hi! I’d like to know if is possible for the orchestrator to manage multiple windows credentials (single sign on) for the single machine. And how does it possible? Thanks
Hi @FedericaL,
High-Density Robots is a feature that ensures a full utilization of each machine at your disposal at its maximum potential. As a result, regardless of the Windows version a machine is running on, if you have multiple users on it, you can register a Robot on each of the users.
Please, go through these links
Susana
Ok Susana, thank you very much for info attached. So, have you tested that by using High-Density Robots feature is possible to manage the Single Sign-On for each user?
Federica
I have the same question. We are looking at using one virtual machine (VDI) with the ability to run multiple robots on the same machine or one Robot with multiple Automation Packages, but need each process to use a different Network ID to be used for credentials and SSO to the applications it will work on when running the process.
The documentation doesn’t tell you this.
