Low code no code automation
Hi
I was wondering :thinking:
Low code no code automation tools are defiantly encouraging citizen developers to automate processes.
How is it going to effect the quality of the code and commercial value of the end product(bot developed).
Will this drift towards Low code no code effect a seasoned developer ?
Hello @AdityaVN!
It seems that you have trouble getting an answer to your question in the first 24 hours.
Let us give you a few hints and helpful links.
First, make sure you browsed through our Forum FAQ Beginner’s Guide. It will teach you what should be included in your topic.
You can check out some of our resources directly, see below:
  1. Always search first. It is the best way to quickly find your answer. Check out the image icon for that.
    Clicking the options button will let you set more specific topic search filters, i.e. only the ones with a solution.
  2. Topic that contains most common solutions with example project files can be found here.
  3. Read our official documentation where you can find a lot of information and instructions about each of our products:
  4. Watch the videos on our official YouTube channel for more visual tutorials.
  5. Meet us and our users on our Community Slack and ask your question there.
Hopefully this will let you easily find the solution/information you need. Once you have it, we would be happy if you could share your findings here and mark it as a solution. This will help other users find it in the future.
Thank you for helping us build our UiPath Community!
Cheers from your friendly
Forum_Staff
There are many factors to consider as well.
First, if you build a Low Code/No code (LCNC) automation, you will still need to deal with the following practical realities:
Is your automation meant only for a small team? If yes, then you can be the lead for your small team and drive the Citizen Developer movement.
If no, then what will be your role as a NCLC Citizen Developer? Will you own the responsibility of maintaining, upgrading and troubleshooting the application across the Enterprise?
What are the compliance and security issues that you as an NCLC developer have to deal with? In an Enterprise an NCLC developer will not have access to all systems across an Enterprise and justifying such access is easier said than done.
Next, will all of these responsibilities eat into the productivity of your actual job function?
NCLC has definitely made things simpler, but it still requires you to learn how to use it and then put it into action beyond the boundaries if your desk. Because if you confine it just to your desk then your business will have very little to gain from it.
thank you @AndyMenon this is insightful.
