Hi everyone,
I’ve been trying to extract the Hash result from SHA1Online, but sometimes it doesn’t work.
Here’s my selector:
It works only for some items, for others it cannot be found. Can you please help me with this issue? thanks!
Hi everyone,
Here’s my selector:
Hi Marta,
where you stuck ?
Sorry, I see that the selector isn’t visible. This is the selector:
It works only from time to time and I have no idea why it won’t work
which activity are you using?
I’m using Get Text
keep only tag=‘span’
If you find it useful mark it as solution and close the thread.
Still doesn’t work…
use get full text
Get Full Text doesn’t help either…
Btw. I’m using IE, since on Chrome I had problems with System1
Issue solved:
