Hi
I’m trying to get through the UiDemo walkthrough.
I’m stuck at the part where you read the config file and then invoke the InitAllApplications file.
I get following error:
What did I get wrong?
Hi
It seems like some or one variable is not set with value.
That is variable is empty
Right, I know.
But how can I figure out which one?
Can you upload or send workflow to me?
Hi @rahatadi,
Thanks, but the issue is solved now. The problem was that
But it is still not clear to me how to figure out which object is not set when you get the above mentioned error.
Any hints on that?
Hi @rahatadi
Is this a link to the webinar?
When I click on it i get a HTTP 400 Bad Request error
@ovi can you please help
can you share your workflow to make trace , this could be because of more than one reason such as the same open activity or no transaction … etc
