I want to add the numbers from column1 ~ 3 and store them in column4.
But the problem is GetTransactionData state does not switch to process.
How can I solve this problem?
P.S I did not touch the init state.
HI
you can get rows one by one
like a datarow as transactionitem
–so once after getting the datarow as item, say
out_TransactionItem = TransactionItem.Rows(0)
where out_TransactionItem is the variables of type datarow (kindly check once with the variable name alone) while TransacttonItem is a datatable
then
–use a assign activty and do like this
out_value = Array.ConvertAll(out_TransactionItem.ItemArray,Function(x) integer.Parse(x)).sum
where out_value is a int32 variable which will have the sum of these three values
hope this would help you
Cheers @Hyun
Hi @Hyun
Use assign activity within for each
Row(“Column4”). ToString=row(1). ToString+row(2). ToString+row(3). ToString
Thanks
Ashwin.S
I want to do addition in process state.
Can you put out_TransactionItem = TransactionItem.Rows(0) in GetTransactionData.xaml workflow?
Fine can i have a view onthe get transaction data in your workflow a screenshot if possible
Cheers @Hyun
