How to use variables for coded automation click selectors?
Hello,
I’m using click selectors in coded workflows. This is fine except for ones that need variables. In this example, I need the anchor to be set to X variable (due to it changing).
The selector looks like this:
I need to enter the variables into these areas, but am unsure how to do so in coded automation.
My current code:
screen.Click(Descriptors.Oracle_Scope.Edge__OTM.ShipmentBox, new ClickOptions
InteractionMode = (UiPath.UIAutomationNext.Enums.NChildInteractionMode)NInteractionMode.HardwareEvents,
ClickType = (UiPath.UIAutomationNext.Enums.NClickType)NClickType.Double
@David_Hernandez2
You need not add in the workflow…assign a variable in the desriptor in object repo…and assign the value to the variable during runtime…so that the value would reflect
Have you managed to do this?
I have tried adding it directly inside the descriptor in the object repo, but no variables show up to use, even though I have plenty throughout the process. And I’ve tried running it with the variable, without validating but it does not work.
@David_Hernandez2
Please add variable like this {{variableTest}}
cheers
I get this message:
But I do have it set:
@David_Hernandez2
This is only a warning…during runtime it ahould take the value if set
Mhm, still getting “Couldn’t find selector” error in runtime. I’ll work on it a bit more.
@David_Hernandez2
The innertext should exactly match…to check use the same in a normal workflow and correct the selector and then use in coded
