Hello,
I have the problem that an indication of the website, where I am trying to click a button is not possible. It always selects the whole website and does not let me select a part of it.
I was able to set a selector for a button called “Export”, which has the following Code if you inspect it:
<button class="MuiButtonBase-root MuiButton-root MuiButton-outlined jss608 jss668" tabindex="0" type="button" data-test-id="tab-export-button" aria-disabled="false" style="margin-bottom: 10px; padding: 5px 6px 5px 13px;" uipath_custom_id="4"><span class="MuiButton-label">Export<svg class="MuiSvgIcon-root jss47 jss669 MuiSvgIcon-colorPrimary MuiSvgIcon-fontSizeSmall" focusable="false" viewBox="0 0 24 24" aria-hidden="true"><path d="M16.59 8.59L12 13.17 7.41 8.59 6 10l6 6 6-6z"></path></svg></span><span class="MuiTouchRipple-root"></span></button>
The selector with > <webctrl aaname='Export' tag='BUTTON' />
works
Now I want to select a button, which appears after pressing the above mentioned button and it has the following inspection code:
<li class="MuiButtonBase-root MuiListItem-root MuiMenuItem-root jss549 MuiMenuItem-gutters MuiListItem-gutters MuiListItem-button" tabindex="0" role="menuitem" aria-disabled="false" data-test-id="export-portfolio-all">All<p class="MuiTypography-root MuiTypography-body1" data-test-id="export-portfolio-all-number" style="margin-left: 5px;">(5030)</p><span class="MuiTouchRipple-root"></span></li>
I can not find out how to select the last button, without indication
