how to run multiple process using cmd in same machine and same time
Hi @Bala_krish
Robot execution can only handle one process at the same time per 1 user account. This means that you would need High Density setup with a Windows Server that can run multiple user accounts at the same time, effectively allowing you to run multiple processes on the same machine ![]()
See here to learn more about High Density setup:
https://robot.uipath.com/docs/about-high-density-robots
For the list of available command line parameters for the robot themselves, see here:
