Hi, I want to read the column and their sub column and write into word file. Please find below screenshot for reference.
I want to read the Gender column and Male, Female, Other are sub columns as below
Above is the output format should look like
When you read the page as datatable(dt) with header un checked you will get the values into single cells in datatable
for example Gender in your scenario can be accessed as dt.rows(0)(4).ToString
and for male female and others dt.rows(3)(4).ToString,dt.rows(3)(5).ToString and dt.rows(3)(6).ToString
cheers
Thanks Anil, Let me try with this method
