Hi,Everone
For my Flow i want to Get date in Excel file.
ex.if to day is :09/27/2022 i want to get date next row in excel file (Output 09/28/2022)
- if tomorrow 09/28/2022 i want to get date next row in excel file (Output 09/29/2022)
Hi,Everone
need more details. you want to read or write?
Hello @punnipah
You can use the index to achieve this.
Dt.Rows.IndexOf(row) will give you the current index. use an if condition, IF it meets the requirement then use an Get Row item activity for the next index.
Thanks
Sorry i want to write date in to web forms.
i want to get Row item activity for the next index
Hello @punnipah ,
Please try this to get the row index:
datatabel.Rows.IndexOf(Row)
Please try this to get the value from the next row:
datatabel(datatabel.Rows.IndexOf(Row))(yourColumnIndexOrColumnName).ToString
@punnipah
please try this one.
Next Day -
row(“YourColumnName”).AddDays(1).Tostring(“dd/MM/yyyy HH : mm : ss”)
merhaba bu sorunun cevabını bulursan bana da iletir misin?
@punnipah
Try this
DateTime.ParseExact(CurrentRow("Date").tostring.trim,"MM/dd/yyyy HH:mm:ss",System.Globalization.CultureInfo.InvariantCulture).AddDays(1).tostring("MM/dd/yyyy")
Hello @senolsen194 , Welcome to UiPath Community
Try this , it may help you
use row instead of current row
DateTime.ParseExact(Row("Due Bank Mobile & FBB").tostring.trim,"MM/dd/yyyy HH:mm:ss",System.Globalization.CultureInfo.InvariantCulture).AddDays(1).tostring("MM/dd/yyyy")
Use Row(“YourColumn name”)
@prithivi_raj_shanmugam are you trying to convert date to next date?
no, I don’t have any issue, I was trying to provide solution
@prithivi_raj_shanmugam have you try my suggested solution?
no, I haven’t
@prithivi_raj_shanmugam wao, you can try, I think you have no trust on me ![]()
