I have .msg file at some specific location i have to read those .msg email body data
you can use
for each item at location
body =item.body
thanks
navneet
@Navneetj3
That is only .msg file. How and which object i will use to load .msg file.
Can you provide me some code how will i load .msg file in MailMessage object
@pankajs3 from which app you have downloaded the .msg file. if you are using outlook then i think you can use mailmessage object and read the item .
@Navneetj3
yes i am using outlook.
But how will i use MailMessage object for .msg file. How can i convert a file (.msg) to MailMessage. Actually i have use MailMessage activity to read outlook account application specific folder but i am not getting how can i read .msg file saved specific directory.
I have one another question is that
“ D:// ” location i have 5 “ .msg ” file
how can i read each “ .msg ” file body, Subject, From and To text.
I would like to load a file with .msg extension, and after that I want to convert the msg file to a MailMessage object to get the MailMessage’s attachments, subject, body, etc…
How should I do it?
Hi pankajs3,
this can help you.
Thanks!
Navneet Jain
Hello, could you be more specific with the procedure, I tried it in the notepad oeri I have errors, could you help me please.
