hey @alexis.mendoza ,
Read below thread
Read below thread
Hi @alexis.mendoza
Check the below thread
Hope it helps!!
It does not work If you are pasting the images but on top of everything, what is required is that you paste them into their corresponding cell
Please try the above vba
https://forum.uipath.com/t/how-to-insert-images-into-excel-cells/567247/23?u=anil_g
cheers
Which version of Excel do you use? In my environment (Excel2019), it works as the following image…
I have office 365
Is there something in the excel settings that you need to enable?
Find the bug.
Find the bug.
it works, but it’s ensimating the images, is there a way to autofit the excel cells?
I’m having a problem like this, how do I make the clipboard public? please provide the method in the form of an image or file
Hi i have tried this and it works . But the images which i am trying to paste are enlarged and they are over lapping . Is there any way i can resize them and paste each image in a totally different cell like one image in A2 and another in E1 like this ?
Harish
