How to create & get output from radio buttons in mail body
Hi Guys
I have to create radio button option in send outlook mail body using html & have to get the output of the user’s response for the radio option.
I am not familair with html so I get a html code from a website & create the option in mail body in the below format.
Example of Radio Button Please select:
Approve
Reject
Using this I can able to create the radio option (Approve, Reject) in mail body but I have to know which option is selected by the user in mail body.
How to get the user response output?
Thanks in Advance :slight_smile:
Hi
Have a view on this below thread which was discussed on same note and I hope you can integrate With ur code
Cheers @mohamedalthaf
@mohamedalthaf
On click of approve of reject ideally you need would do an action or event like send email with a specific mail body …int hat mail body include a keyword for approve and reject and check what value it is
@Palaniyappan Thanks brother!! This is working as expected.
Glad it got resolved @mohamedalthaf
