I was trying to for each mail check if there is regular expression in mailbody then I want to if there is this regular expression in mail body then I want to save the file path of attachment in that email and the password to an excel (Password and path.xlsx)
I was wondering also if I can open or unprotect the password protected excel files that I saved into excel (Password and path.xlsx) and process the files inside.
Hello @Simple1!
It seems that you have trouble getting an answer to your question in the first 24 hours.
Let us give you a few hints and helpful links.
First, make sure you browsed through our Forum FAQ Beginner’s Guide. It will teach you what should be included in your topic.
You can check out some of our resources directly, see below:
Always search first. It is the best way to quickly find your answer. Check out the
icon for that.
Clicking the options button will let you set more specific topic search filters, i.e. only the ones with a solution. -
Topic that contains most common solutions with example project files can be found here.
Read our official documentation where you can find a lot of information and instructions about each of our products:
Watch the videos on our official YouTube channel for more visual tutorials.
Meet us and our users on our Community Slack and ask your question there.
Hopefully this will let you easily find the solution/information you need. Once you have it, we would be happy if you could share your findings here and mark it as a solution. This will help other users find it in the future.
Thank you for helping us build our UiPath Community!
Cheers from your friendly
Forum_Staff
Hi @Simple1,
- If password is written in email as a plain text there will be no problems to take it with use of regex as you said and write to excel table. Anyway please know that this is huge security gap and completely not a best practice.
- It is possible. Just use Excel Application Scope activity where you can define these in parameters:
