Could you please help with the below requirement with Uipath workflow?
I’m new to the Uipath
I want to highlights duplicates in column A & C
have attached images for the example input and output
Input
Output
Thank You
Input
Output
Thank You
hi, welcome to the forum
First, let’s get repetitive values only to array of string
arr = (From row In dt
Group row By k=row("ColName").ToString.Trim Into grp=Group
Where grp.Count >1
Select r = grp(0)("ColName").ToString).ToArray
Second, let’s find indexes of rows in dt , that should be colored (also array of string)
rows_to_color = (From row In dt
Where Array.IndexOf(arr, row("ColName").ToString) > -1
Select val = dt.Rows.IndexOf(row).ToString).ToArray
Than use Set Range Color activity ![]()
Main.xaml (8.9 KB)
Thank you so much ![]()
