Hello I just need help to get specific text from email body using Regex on Studio X. I need the PO number that usually starts with 450***** so that i can open in SAP and create internal ticket using studio x
Sample email body
"Hi Karen,
4506792481 – order is on hold as FTQ-2473824 is standard SKU but PO is Co-term.
Please provide revised PO.
Yvonne Toh
Order Management
Fortinet (S) Pte Ltd
How about the following sample?
regex pattern
450\d+
NewBlankTask20231026-1.zip (50.0 KB)
Hi @Lolong_Alvin
Inupt= "Hi Karen,
        Yvonne Toh
        Order Management
        Fortinet (S) Pte Ltd"
Output= System.Text.RegularExpressions.Regex.Match(Input,"(?<=\n\s*)\d+").Value
Hope it helps!!
You can try something like this using assign activity
Stroutput = System.Text.RegularExpressions.Regex.Match(Strinput.ToString, β€œ450\d+”).Value.ToString
Explanation
Cheers @Lolong_Alvin
This 450\d+ worked. Thank you :slight_smile:
Hope it’s clarified
If yes
@Lolong_Alvin
450\d+ worked.
Thank you @Yoichi :slight_smile:
HI,
FYI, if PO number has fixed digits, the following may be better.
\b450\d{7}\b
(If PO number is always 10 digits)
