zaffan.isa
(Ahmad Zaffan bin Muhamad Isa)
1
Hello guys,
I am trying to write this formula:
=IF(OR(ISBLANK($C2),OR(AND($I2=“COMP”,$N2=“”,$Y2=“”),AND($I2=“COMP”,NOT(ISBLANK($N2)),NOT(ISBLANK($Y2))))),“”, TODAY()-$C2)
But UiPath is giving me , compiler error encountered processing expression.
Can somone help me on this matter?
Yoichi
(Yoichi)
2
What activity do you use? Basically it will be as the following.
"=IF(OR(ISBLANK($C2),OR(AND($I2=""COMP"",$N2="""",$Y2=""""),AND($I2=""COMP"",NOT(ISBLANK($N2)),NOT(ISBLANK($Y2))))),"""", TODAY()-$C2)"
zaffan.isa
3
i am not using the modern one. i am using the conventional write cell activity.
Do you think i need to use modern write cell activity in order to make this formula works?
Yoichi
(Yoichi)
4
No, it also work in classic write cell as the following.
![image](https://global.discourse-cdn.com/uipath/original/4X/b/1/e/b1ed88518262824a83125fb63d3c2104780c8382.png)
Please check your expression string (or copy and paste the above expression)
zaffan.isa
5
Thanks @Yoichi … It works. But, can you explain a bit for my learning purpose…
From my observation, you change my excel formula a bit…
Can you explain the reason behind of the change?
Yoichi
(Yoichi)
6
In VisualBasic, we need express "
as ""
because double quote is special character.
For example, "COMP"
should be ""COMP""
should be """"
Hope this helps you.
system
(system)
Closed
7
