For the same selector , bot is working fine in development machine and failing in UAT machine
There may be an issue in Properties of Activity like in Some environment Bot is working Prefect with Simulate Click and in some Environment Bot is working prefect with Send Window or Window Message.
You should try it by Changing its property in UAT.
But there is no studio in UAT… how can I update selectors?
You can update your selectors in Development machine and publish Package in Orchestrator,
In UAT Login to same orchestrator so, you can directly run bot by Uipath Assistant or Orchestrator.
I am working on three applications, can I use delay for the next applications to wait till the previous application has downloaded the data
Hi! Welcome to Community!
There could be many reasons…
- Check the extension.
- System Configurations.
- Browser version
- Display size
Check with this
NaNi
Okay i wi check it
You can use delay or timeout or set property as wait for ready to Complete.
It is depending upon which Activities you are using for download.
Okay I am checking
But I can only update selectors or properties in dev environment?
You can do both in Dev Environment.
