We have an Excel macro that takes about 2 or 3 seconds to execute when doing it manually. But when the robot does it it takes up to a minute or more. We are executing the macro via UI.
This is a huge problem because we have to run this macro many times within a execution.
We are already executing the macro with hotkeys (alt+F8 to open the “View macros” window and then selecting the macro).
We can also simply press a button that triggers the macro but it does not change anything, in both cases the macro still takes way too long compared to manual execution.
any thing you are doing in the vba like formatting you must be chnging the range of string to number thats why it is taking time. but you can try by providing that same formatting by open excel and send multiple hotkeys like ctrl+a for select all ctrl+b for bold for going to randome column try ctrl+g and trype the column name then send hotkey like ctrl+shift+end to select data till end then do the formatting. it will not take time. you can send using alt button also.
Hello @Anil_G@Yoichi is there any solution for this please support.
