Still having load python script error.
Can you define the standard way to configure this activity.
Hi Padegal,
It seems the reason is behind where the python code is executed and therefore unable to locate the file. My own workaround on this is to pass the path of the file as an argument, therefore you can define it as a variable the uipath env.
@tome.lourenco, welcome and thank you for posting. I am having a similar issue which I havenât resolved yet. Somewhere in the forum I found this code:
import sys
import os
sys.path.append(os.path.dirname(os.path.realpath(__file__)))
which the post said to put just before the âimport your-module-hereâ call. The reason given was that the software restriction in place make UiPath look for the py script in the activities directory. I will try your workaround as well. See e.g. this post, this one that says Python 3.7 wonât work (seems doubtful now). I am certainly hoping Python 3.7 will work . . .
EDIT: Just in case 3.7 wonât work, and perhaps thatâs so, I installed Python 3.6 in a virtualenv and pointed the workflow above (CultivationFacilityScoreBreakdown) to that version of Python. I didnât get any path errors, but I did get this:
burque505
This may or may not help, but it is a working version of invoking a python script. The script is based on a pluralsight course exercise which creates aircraft objects which have various methods, including the airline name which I access in this UiPath workflow. The answer in this case is âBAâ. The aircraft object is created in the py script using the make_flight function so you donât need to worry about that here.
It is set up so that you just have to provide your path to the python_36 executable file so that it can be read by the scope.
InvokePython.zip (3.1 KB)
@ronanpeter, thank you! That worked perfectly when I used a 64-bit version of Python 3.6. Just in case anyone else tries it with 32-bit, for me at least it crashed UiPath.
Greatly appreciated! If I can figure out how to mark my issue just above as âsolvedâ due to your post I will. Please bear with me.
burque505
On my machine at least the solution given by @ronanpeter, with a working workflow attached, solved it for me. Please see below my post for his solution. I did not need to use a virtualenv for it, I just pointed my script to where Python 3.6 resides, i.e. C:\Python36\ (just the folder name, not the executable).
burque505
