Hi guys, I have to create Appscript project through uipath but I am not able achieve this.
Everytime I am getting an error.
Can anybody have idea that what are the mandatory steps to be follow to create and run Appscript projects.
Please share the steps that need to be follow.
I tried these steps:
I) Created one New GCP project
Ii) Enabled gDrive,gsheet, Appscript API on Google cloud console.
Iii) created oauth credentials
Iv) Created new spreadsheet on Gdrive
V) in Uipath studio - took an activity gsuite scope passed the oauth credentials.
Vi) Taken create Appscript activity
It seems that you have trouble getting an answer to your question in the first 24 hours.
Let us give you a few hints and helpful links.
First, make sure you browsed through our Forum FAQ Beginner’s Guide. It will teach you what should be included in your topic.
You can check out some of our resources directly, see below:
Always search first. It is the best way to quickly find your answer. Check out the icon for that.
Clicking the options button will let you set more specific topic search filters, i.e. only the ones with a solution.
Topic that contains most common solutions with example project files can be found here.
Read our official documentation where you can find a lot of information and instructions about each of our products:
Meet us and our users on our Community Slack and ask your question there.
Hopefully this will let you easily find the solution/information you need. Once you have it, we would be happy if you could share your findings here and mark it as a solution. This will help other users find it in the future.
Thank you for helping us build our UiPath Community!
