hi to all
I am using the click activity in sap, when i press f4 one popup will come in that i have to chose on option
but it is selecting whole pop window. suggest me what i can do for that.
hi to all
Hi @Harish_pavuluri,
Please try to F3 or F4 changes will effect for select region for indicate on screen
Omkar P
take a look in to screenshot. i want to select (DAILYSALESREG Daily Sales Register - Common)
line but it is selecting window.
F3 region is not working?
Try F2 delay put mouse over daily sales reg
F4 press continues observe difference your screen shot is showing default below are the options
AA
default
UIA
Sorry forgot about f4 see the given screen shots
when i selecting that block showing in screen its fin.
Did you try to update the package and try ? Try to update this package UiPath.UiAutomation.Activities and check if this selections are wroking .
Thanks for your reply its already updated.
Harish still no luck for F4
@ reddy
Yes
not only click activity if type into activity also doing same thing.
