Hi Click activity not work to click on button not in single time
Hi @Aditya10989,
Seems that you selector is not “universal” and not fits to the button after another run. You need to make it more universal. More info here (check all sites related to selectors topic):
Other way is to use Computer Vision package and it’s CV Click activity.
hi @Aditya10989
Can you check the selectors based on parentid check whether it is dynamic or some other property
@AshwinS2 means sorry did not understand
hi @Aditya10989
In the selector check the parentiid of various records is the number been changed or not
Thanks
Ashwin S
Look at your very first screen in this topic and compare it to this selector you showed now. Those are completely different.
@Pablito its only difference the parent id.I did not select the parent id in selector.how can I remove this…??
Hi @Aditya10989
Without the parent id ensure the selector is working fine
Thanks
Ashwin S
You should check out the Academy and do the Level 1 - Foundation training. There is everything explained including selectors. It’s one of the basic thing which should be known before starting the journey with RPA.
