Click activity does not work after using send hotkey(win+d)
Dear all,
Click activity does not work after using send hotkey(win+d), but if I switch the sequence of the two activities, means firstly use click activity and then send hotkey(win+d), it works! I have also checked with UI explorer whether there is problem with the selector, but seems there is no problem.
Hi @zangyuchen2008
Did you try double click image activity?
Thanks
Prankur
@zangyuchen2008
Try with omiting the title of the first line in selector using the keyword “omit:” as mentioned below :
Hi @zangyuchen2008,
Please try “Win+m” instead of “Win+d”. ‘win+m’ will minimize all windows and sets the focus to desktop.
Warm regards,
Nimin
Ah, it works, thank you!
