Attach Window (First problem)
i can’t find attach window ? what is the solution
See if you got the uipath.uiautomation.activities package installed, if you dont got it you need reinstall the Studio
Hi @k.sharafeldin !
Are you using the modern folder option ?
If yes, in the activities panel, click on the filter button, then on show classic:
