Will there be problems if you changed PCs with UiPath Studio and continue the development process?
Good morning friends;
I have a question please, I have the UiPath Studio on a development PC and the UiPath service on a remote server.
The problem is that the PC where I develop is failing and I will change to another. My doubt is about the actions that I must do to be able to continue developing normally on the new PC, I have the folders of the bots that I have been doing, I would move those folders to the new PC and then I would connect to the orchestrator, right?
Are there other things I should take into account?
I thank you in advance for your advice.
Hi @Lynx ,
Please do take backup of the files/Folders that were being used In the UiPath Folder.
Since, it is a Development PC, It should be fine.
Unless, there were additional setup done to make a process work , maybe adding nupkg or dll files in the Program Data / Packages folder, it should be good to continue with your shifting Process.
We could however, do the same steps once configured for the Old Machine into the new machine.
Thank you very much for answering
Good morning friend;
Today I changed machines, copied all the projects to the new pc, “uipath folder” but when I try to update a project I get the following message:
@Lynx It says the package already exists so you can’t publish this until you update the package. Please follow the below steps to update the package
  • Open Project.json file which present in your project folder
Capture
  • Change the project version to a different version (Given version should not present in orch)
Capture1
  • Save the file and re open the project then try to publish it
Thank you very much @ushu for the help, it worked!
